Scatola movimento centrale d'artigano | Tretlagergehaeuse - Rahmenbau-Liebe Im Detail (Handwerkskunst) | elaborate bottom bracket shells
Cicli Domenicali
Via Malvola 4, Bologna 🍝 actually ragu :D (and the official recipe got changed recently! I am still vegetarian nonetheless)
Emilia-Romagna
dal 1955
Re: Scatola movimento centrale d'artigano | Tretlagergehaeuse - Rahmenbau-Liebe Im Detail (Handwerkskunst) | elaborate bottom bracket shells
Ich würde hier sogar mal eine Ausnahme machen und dem dahinter stehenden Lotus dem Rennrad den Vorzug geben. :D
Aus Prinzip schon nicht :D.
🚲 4️⃣ life
PS: schon datt dritte Domeniclai hier, mindestens von zwei verschiedenen Loetern, erster ist mit Sicherheit Umberto Chiesa, zweiter Giorgio Lucchini und der Domenicali aus Columbus Max... 🤷‍♂️
Domenicali - sonntags/sonntaeglich - on sundays ☀️ 😎 :D from Bologna, Emilia-Romagna
this time probably by Duelle then Gille,- Giorgio Lucchini from Rimini, Emilia-Romagna build for shops&brands like Adriatica (one frame displayed here in the thread by GL Giorgio Lucchini) of Misano Adriatico form Pesaro, Marche and his other brand Primavera (only too Primavera in this thread both by Ciöcc Giovanni Pelizzoli, one marked Adriactica and Primavera the same time 😂) and Elementi from Rimini and Cicli Nanni from Cesenatico, Forlì-Cesena, Emilia-Romagna
👗 vernicaitura by the 0ne and only Mario Martini, from Lugo, Ravenna, Emilia-Romagna!
Cinelli tipo spoiler scatola movimento centrale microfusa, progettata da Gianni Gabella 1984, con logo flying C di Italo Lupi del 1979 prodotta da MFI Microfusione Italiana - bottom bracket shell investment cast, designed by Gianni Gabella 1984, with Cinelli new flying C logo by Italo Lupi 1979, produced by MFI Microfusione Italiana - with patent :D
Anhang anzeigen 1340488Anhang anzeigen 1340494Anhang anzeigen 1340493Anhang anzeigen 1340492Anhang anzeigen 1340491Anhang anzeigen 1340489Anhang anzeigen 1340490
weil's s schoen ist
Achtung ⬆️ Spoiler ❗ Wiederholung ⬆️ aber Augenmerk Kettenstreben Lackierung 👗 🎨
Venturi aus Cesena, Emilia-Romagna wahrscheinlich von Giorgio Lucchini 🤷‍♂️ 🙏
Kettenstreben Lackierung!
Cicli Venturi
fillet brazed, no head tube lugs, nice bottom bracket shell
even with pretty flat & oval chainstays, the right one ist indented on the outside, for the crankarm & chainring to pass 😳
Bruce Gordon
613 Second Street, Petaluma, CA 94952
Bruce Gordon Cycles manufactured custom bicycles for 46 years, beginning in 1974. In college Bruce was an art major with a focus in photography.
G020477
Gordon | second frame | April '77 (1977)
Franco Priori
Via Milano 2, 26100, Cremona 🇮🇹
not to be confused with Arnaldo Priori of Senago ,Milano, Lomabrdia
pinza d'oro Franco Priori (*1928) who did not braze his frames! named after the greater pinza d'oro Giuseppe De Grandi »Pinella« (1908-1981)! welcher erstamls den Titel pinza d'oro vom damaligen TdF Direktor Jacques Goddet verliehen bekam, um 1949 nachdem dieser Zeuge ward eines Schlauchreifenwechslen in Rekordzeit an einem Rennvelo des Campinissimo Coppi.
Pinella ward um 1937 & 1938 von Girardegno zur Tdf gerufen, und kuemmert sich auch um das Rad Gino Bartalis.
1952 rief Coppi ihn zu Bianchi
etc.
*gibt Franco Priori aus Cremona mit von Pelà und oder Irio Tommasini (echte Kenner koennen dies unterscheiden!) PSM Sante "Santino" Pogliaghi, Milano, Fiorelli oder von Losa
Mir faellt kein terzist ein, der fuer Priori gebaut hat, der besser ist oder ebenbuertig.
Marastoni und Gilardi beispielsweise nuescht, Messori nada.
Naja
*Pela und Fiorelli sind hier vertreten, das PSM Priori ist auf insta bei Josh @biciclette_d_epoca
BY LOSA
Ein Giuseppe "Pino" Pelà
(Roh)Rahmen, finalisiert in der Emilia-Romagna
von wem 🤷‍♂️
A Giuseppe "Pino" Pelà
(Raw) frame, finalised in Emilia-Romagna
by whom 🤷‍♂️
Un telaio grezzo di Giuseppe "Pino" Pelà,
finalizzato in Emilia-Romagna
da chi 🤷‍♂️
O. Grenzi maybe👶 <- baby 👼🏾
possible connection is F.lli (sons | Soehne) Chierci from Parma (owned the brand Maurizio)
for Villa
Cicli Villa
since 1928 - 80s
Amleto Villa
headset not original as levers (i guess brake levers) 🙈 😅 😮‍💨
PAT. 70 Campag "group"-set ;- )
Palmares: Marco Cimatti siegreich bei den Olympischen Spielen Anno 1932 in Los Angeles, auf einer Villa, Diszplin Mannschaftsverfolgung (Bahn, 4000m, Vierer Team)
Langweilig restauriertes Colnago.
Interessant ist das Tretlager und die Kettenstrebenbrücke…bestimmt ist der Rahmen nicht von den typischen Colnagomachern wie Rauler gemacht.
Anhang anzeigen 1356186Anhang anzeigen 1356187Anhang anzeigen 1356188Anhang anzeigen 1356189Anhang anzeigen 1356190Anhang anzeigen 1356191Anhang anzeigen 1356192Anhang anzeigen 1356193
keine Ahnung ob es immer zwei oder drei Stirche als Ausfraesung sind (wohl eher ZWEI), aber sehr markant dieses "W"-foermige Einpraegung auf dem integrigeten Unterstrebensteg.
Hat mich gleich an dieses Krapf Losa s erinnert, selbes TLG.
von wem 🤷‍♂️
by whom 🤷‍♂️
da chi 🤷‍♂️
for Villa
Cicli Villa
since 1928 - 80s
Amleto Villa
headset not original as levers (i guess shifting levers) 🙈 😅 😮‍💨
Anhang anzeigen 1364447Anhang anzeigen 1364448Anhang anzeigen 1364455Anhang anzeigen 1364449Anhang anzeigen 1364453Anhang anzeigen 1364450Anhang anzeigen 1364451Anhang anzeigen 1364452Anhang anzeigen 1364454
Ma che bello! Alleine V I L L A Decals!
Masi
75-76
Prestige pr0totype too boh 🤷🏾‍♂️
different fork crown panto
(not on bhovey!!!)
http://bhovey.com/Masi/MasiBits/Fork.htm
dafuer chronologisch folgende Eintraege, Nummer 2 und 3
2.Pelà 3. Das Verstaerkungsblech, am prominentesten so bei wem wohl, tuellich Pelà
nette Zeitspanne, Periode, Zeitrahmen und Fenster 🪟 :D
jejejeje jajajaja
Screenshot 2023-12-13 at 23-09-20 96190a1b-5b70-439d-bea8-b76cd5e2baf4 (AVIF-Grafik 1500 × 200...png
Screenshot 2023-12-13 at 23-08-52 6008d591-6432-4cc6-848b-75fa5a394be0 (AVIF-Grafik 1333 × 100...png
Screenshot 2023-12-13 at 23-08-32 666423d1-67cd-422d-a488-c32875729ce8 (AVIF-Grafik 1500 × 200...png
Screenshot 2023-12-13 at 23-07-39 8f1682ff-4a37-4254-bce6-512c4898b22b (AVIF-Grafik 1500 × 200...png
Screenshot 2023-12-13 at 23-09-35 c3643169-5ffc-4632-9452-35879a80a754 (AVIF-Grafik 1500 × 200...png
Screenshot 2023-12-13 at 23-09-03 12e9cdf8-cdf0-4f17-b409-ba786f6b5cd9 (AVIF-Grafik 1500 × 200...png
Masi
75-76
(not on bhovey!!!)
jejejeje jajajaja
Anhang anzeigen 1364528Anhang anzeigen 1364530Anhang anzeigen 1364531Anhang anzeigen 1364532Anhang anzeigen 1364527Anhang anzeigen 1364529
Das untere Masi sieht aus wie ein Repro von Simone.
