Rafael Six
- 16 November 2021
Weil Trekkingrad uncool!Warum ein Endurance mit hochgedrehtem Vorbau, ungekürztem Gabelschaft?
Yesterday, I traveled to another city to try sizes 58 and 60, but the size 60 had been sold days before I arrived.You would need to take a picture with your hands in the hoods. If you are in the drops, the reach is a lot shorter so it becomes hard to tell, whether the bike fits or not. You should also definitely lower the saddle, when you try that. Thats currently way too high. It is usually easier to get the fit correct on a smaller frame, so if possible, I would always go for the smaller option.
It can be confusing to find the right size :/Yesterday, I traveled to another city to try sizes 58 and 60, but the size 60 had been sold days before I arrived.
At least I was able to try size 58 again and took some photos. What do you think? The seat post is nearly at its maximum height. Unlike the seller from last week, this one told me that, in his opinion, size 58 is borderline but still okay. He was 50/50, saying that size 60 might be better. I’m even more confused now than I was before.
https://imgur.com/a/Gm56eWH
I was in the same Situation deciding between Agree 60 and 62. The calculator said 60, one shop suggested 58, one 60 and two 62. After some testdrives I have made the decision for in my opinion the most comfortable size 62. But an other person with identical measurements possibly decides for 58 in the same situation.Yesterday, I traveled to another city to try sizes 58 and 60, but the size 60 had been sold days before I arrived.
Yes, but with the size 60 frame, I feel even more upright (https://www.rennrad-news.de/forum/threads/cube-attain-slx-2025-rahmengröße.197030/post-6432008). I'm starting to have mixed feelings about this, but I really don’t want to let go of this model because its price-to-performance ratio is unbeatableIt can be confusing to find the right size :/
In the second photo you look quite upright to me which would suggest that a little bit more reach could be good (i. e. a larger frame or a longer stem), depending on how sporty vs relaxed you would like to ride. It seems like you probably are in between both sizes. In that case most bike fitters suggest the smaller one because it is easier to fit a larger person on a smaller bike than the other way around.
Could you please share your measurements ?I was in the same Situation deciding between Agree 60 and 62. The calculator said 60, one shop suggested 58, one 60 and two 62. After some testdrives I have made the decision for in my opinion the most comfortable size 62. But an other person with identical measurements possibly decides for 58 in the same situation.
There are plenty of spacer you could remove, and the stem looks like a 0° pointing thus upwards, maybe it could be replaced by a more flat reaching -6°.Yes, I know. I’m asking because I’m also considering the Agree model, as I wouldn’t be in such an upright position.
Der Reach wird immer von der Lenkerklemmung gemessen, egal wie viel Grad Rückbiegung der Oberlenker hat. Also die Position der Schaltbremshebel ist gleich wie bei einem Lenker mit 72 mm Reach ohne Rückbiegung.72mm reach und sogar -5% rückbiegung.
Absolut gesehen hast du sicher lange Beine, aber es kommt ja auf die Relation an. Ich bin knapp 10 cm kleiner als du und hab nur 1 cm kürzere BeineUnd ich dachtebich sei mit der 92,5cm schrittlänge schon Langbeiner
Das ist nochmal ein super Hinweis! Werde Mitte der Woche mal bei einem Cube Händler vorbeischauen und im besten Fall die drei Größen probierenMit RG58 ist das Rad sicher etwas agiler und die Sitzposition etwas sportlicher als mit RG60.
Wenn du hingegen noch aufrechter sitzen möchtest, ist auch RG62 eine Überlegung wert. Da ist der Reach gegenüber dem RG60 nur gerade 1mm grösser, aber der Stack nimmt um 19mm zu. Allerdings ist der Lenkervorbau 10mm grösser als bei RG58/60.
