Scatola movimento centrale d'artigano | Tretlagergehaeuse - Rahmenbau-Liebe Im Detail (Handwerkskunst) | elaborate bottom bracket shells
Anderswo hier nimmer gefunden.
https://www.rennrad-news.de/forum/threads/kein-text-nur-bilder-stille-nichts.116754/post-3614584
Immerhin sieht man ein Schimmerlein des Tretlagergehaeuses von unten... 😅:D
fast neun Jahre ist es her...
Nen Corrado Paratella Steher 😳 ;- ).
Cicli Paratella
maestro artigiano Corrado Paratella (born at Pontelongo, Padova)
(1912 - 1994)
via Cuneo 7, Torino
bici mezzofondo
Paratella build only 25-40 frames a year and in total ca. 700-800.
Famous for his refined production of espically road & stayer frames.
together with Pelà, Picchio and Beltramo the magic four master framebuilders of turin.
Close friend of Tullio Campagnolo with whom he raced togheter in the "Niccolò Biondi Capri" team in the 30s.
As stated in the by Campagnolo, in limited number, published book "il gigante e la lima", Tullio before releasing a component on the market, always visited (Corrado) Paratella to get his opinion and have it tested.
Re: Scatola movimento centrale d'artigano | Tretlagergehaeuse - Rahmenbau-Liebe Im Detail (Handwerkskunst) | elaborate bottom bracket shells
Cicli Paratella
Anhang anzeigen 1481650Anhang anzeigen 1481649
(1912 - 1994)
via Cuneo 7, Torino
bici mezzofondo
As stated in the by Campagnolo, in limited number, published book "il gigante e la lima", Tullio before releasing a component on the market, always visited (Corrado) Paratella to get his opinion and have it tested.Anhang anzeigen 1481627Anhang anzeigen 1481634
Anhang anzeigen 1481633Anhang anzeigen 1481632Anhang anzeigen 1481629Anhang anzeigen 1481631Anhang anzeigen 1481630Anhang anzeigen 1481628
Fantastisch!
Tommasini told about his teacher Pelà
"Pelà was tough," says Tommasini. 'He made seven frames and seven forks a day. By himself. He didn't have jigs. People went there and understood nothing of what he did. We remained friends and every now and then he would say: 'I'll stop in a few years'. When I went to Turin, maybe passing by Nisi's (famous for rims) to buy parts, then I would stop at his place. If I asked him for anything he would make it for me. Something that others, even very high-profile ones, didn't do'.
Tommasini lights up remembering his master and friend. 'He made a frame in four hours, for Bracke (a Belgian cyclist), for the Hour Record. You live off these things here'.
Anhang anzeigen 1465888Una bicicletta, quando è fatta bene, è da ammirare. E per farla bene ci sono dei particolari che tanti non vedono. Anche nella saldatura, che è importante. La saldatura delle congiunzioni tanti la limavano. Dicevano: “Ora poi c’è da limare…” Ma la congiunzione non la devi limare. La devi tirare prima. Poi quando la vai a saldare ci vuole tecnica. Prima si saldava con il propano e l’ossigeno. Veniva un bel dardo e da questo potevi dargli la forma che volevi. Quando avevi finito saldarvi il tutto, con il sistema del Pelà. Si tirava indietro il cannello e l’ossigeno faceva come il riccio, si ritirava, e la congiunzione rimaneva pulita».
ach der letzte Teil :D
A bicycle 🚲 , when it is well made, it is to be admired. And to do it well, there are details that
many people don't see. Even in the brazing, which is important. The brazing
of the joints, a lot of people used to file it down. They used to say: ‘Now you have to file...’
But you don't file the joint. You have to pull it first.
Then when you braze it, it requires technique. They used to braze with propane and
oxygen. It would come out a nice dart and from that you could give it the shape you wanted. When you were done, you would braze it with the Pelà system.
You would pull back the torch and the oxygen would make like a hedgehog 🦔, it would withdraw
and the joint would stay clean.
https://biciclettedepoca.net/news/personaggi-e-campioni/irio-tommasini/
Schon krank die durchschnittliche Qualitaet seiner Rahmen, bei diesen Produktionsvermoegen oder lieber Schaffungswille :D / Leistungsvermoegen, sieben Rahmen und Gabeln rauszuhauen am Tag, war ja schon ein Ein-Loeter Laden.. mit Ehefrau und zwei Zuarbeitern, gehe mal von den Giame Bruedern aus!
Die Qualitaet gereichte von Masi s, zu Merckx unter Faema (1968-69) wohl und sicherlich unter Faemino-Faema (1970) wie das ganze Team einfach oder in 4h fuer Ferdinando »Ferdi« Bracke 🇧🇪 ein Stundenrekord Bahnrad (1968), erster ueber 48 km in einer Stunde...
  • Screenshot 2023-06-23 at 23-39-15 CORA Bicycle frame Package built by Pela of Torino.png
Francesco Moser
superleggera elaborata maybe pre braze-on front derailleurs about 1981/1982...
moser-cat-5-jpg.1484991
(same paint scheme, chromed rear stays and fork.. and cromovelato frame, same fork crown, same seatstay caps)
custom braze-on front derailleur - nello stile di Oriello Tardozzi di Forli, Emilia-Romagna
unbranded Cinelli SCM investment cast bottom bracket shell produced by MFI Microfusione Italiana
coda di rondine / swallowtail connections fo the rears stays to teh dropouts as fork blades to the frokends
cromovelato
456141133_3507426332723427_6295690990998996688_n.jpgFrancesco Moser Super Prestige Pernod Oriello Tardozzi (1).jpgFrancesco Moser Super Prestige Pernod Oriello Tardozzi (5).jpgFrancesco Moser Super Prestige Pernod Oriello Tardozzi (4).jpg
beautiful Anselmo CX (by Losa) & Columbus Air, 3ttt Aerodinamico seatpillar as 3ttt Aero handlebar, and even Nisi Mixer clincher (aero | v-shaped) rims!
recntly sold in Berlina via eBay for under 999€, best offer accepted
Anhang anzeigen 1485975Anhang anzeigen 1485979Anhang anzeigen 1485982Anhang anzeigen 1485976Anhang anzeigen 1485980Anhang anzeigen 1485983Anhang anzeigen 1485981Anhang anzeigen 1485977Anhang anzeigen 1485978Anhang anzeigen 1485984
Eines der schönsten Losas!
Ja, ich glaube dasselbe Anselmo CX Losa samt Nisi Mixer Felgen, schonmal zwei Schnappschuesse auf einem Fahrradmarkt, eingestellt, unter das einzige Crovi Losa.
Sonst noch das verchromte Losa Aero mit ramata Muffen, nun in HongKong....
Crovi
Losa
roto bottom bracket shell and fork crown, investment cast from 1972
Anhang anzeigen 1424366Anhang anzeigen 1424369Anhang anzeigen 1424367Anhang anzeigen 1424368
Losa
aero
like for Anselmo
F.lli Chierici (Maurizio racing bicycles belongs to them), from Parma, investment cast bottom bracket shell
actually for braze-on front derailleur and not clamp-on
Anhang anzeigen 1424370Anhang anzeigen 1424374Anhang anzeigen 1424373Anhang anzeigen 1424372Anhang anzeigen 1424371Anhang anzeigen 1424375
Nisi Mixer :eek: 😳 👅 🤪😜:D
other fork crown
Columbus Aria / air 💨
Cicli Anselmo
in Via Aurelia, 158, 17025 Loano SV, Italy
by Giovanni »Vanni« Losa
originally Via Giuseppe Mazzini, Erba, Como
later moved to Vittuone, Milano
aero shaped down tube
aero shaped seatstays
recessed seat tube for shorter wheel base
no chainstay bridge too
Losa dropouts
Cinelli SCM investment cast bottom bracket shell, with flying »C« (the winged logo / il logo alato), produced / cast by MFI Italiana
Anhang anzeigen 1442945Anhang anzeigen 1442954Anhang anzeigen 1442949Anhang anzeigen 1442953Anhang anzeigen 1442947Anhang anzeigen 1442946Anhang anzeigen 1442948Anhang anzeigen 1442952Anhang anzeigen 1442951Anhang anzeigen 1442950
und der Nachfolger praktisch, kein Cinelli SCM Feinguss Tretlagergehaeuse mehr mit dem ab 1978/79, die Heraldik verabschiedend, neuen "Cinelli alata" (winged) or flying C Logo, entworfen von Italo Lupi, (passend zur Uebernahme '78 Cinelli s, durch den Columbus Eigner Antonio Colombo), das ab 1984 erschienene "Spoiler" Tretlagergehaeuse (mit ehemaligen Patent fuer ein Feinguss Tretlagergehaeuse!)! wie die moderne Version einer "Unicrown" Gabelkrone! ;- ) 🙏🏾
Sehr spezielles Colnago Aerodynamica aus 1980.
Angeblich ist es bei den Olympischen Spielen genutzt worden. Ein sehr ähnliches Rad mit Beleg zu Olympia gibt es hier, gleich sehr schöne Gabel und der spezielle Frontumwerfer ist auch zu sehen.
https://www.flickr.com/.../591.../in/album-72157627029824811
Ist möglicherweise ein Bild von Fahrrad und Text
Anhang anzeigen 1494099Anhang anzeigen 1494101Anhang anzeigen 1494102Anhang anzeigen 1494103Anhang anzeigen 1494104Anhang anzeigen 1494105
Anhang anzeigen 1494096Anhang anzeigen 1494094
Doppelt gemufft hält besser?
