Ich probiere gerade das hier aus und will es die Tage mal testen.
The
Back on Track feature should work automatically any time a route is loaded and if the map has been correctly updated. Once ELEMNT ROAM/BOLT detects you’ve gone off-course, it should quickly calculate the shortest path to get you Back on Track.
Please follow the next steps:
- Once the device is paired with the Elemnt App, go to settings and scroll down to Wifi. Please add your Wifi.
Please, ensure your Wifi respects the following: Wifi Issues
- Double check on both your phone and BOLT that Wifi is correctly connected.
- At this point, go to Manage Maps delete all the unused maps and re-download the only preferred Map (ex. Belgium). Downloading a new map can take up to 15 minutes depending on the connection used. I would recommend not locking the phone during the process.
After this, please perform a Gps calibration:
- Turn the Bolt on while outdoors with a clear view to the sky
- After the warming up process is completed, using the page button, scroll to the map page of the Bolt
- Initially you will see “acquiring GPS” in the top corner of the maps screen
- Once acquiring GPS is no longer visible, press start ride
Once you have completed these steps please double check that you have enabled the ‘Reroute Automatically’ option within the settings tab of the app, under the heading RIDE.
