Scatola movimento centrale d'artigano | Tretlagergehaeuse - Rahmenbau-Liebe Im Detail (Handwerkskunst) | elaborate bottom bracket shells
Re: Scatola movimento centrale d'artigano | Tretlagergehaeuse - Rahmenbau-Liebe Im Detail (Handwerkskunst) | elaborate bottom bracket shells
Priori
Columbus Air fork crown* (with AER panto)
bottom bracket shell just like a Cinelli invemstent cast just without branding by mircofusione italiana
Losa lugs as at least the head tube ones
dimpled seta-tube*
panto on bottom bracket shell*
*all often seen on Losa build/brazed frames of the time...
Priori
beautiful paint! 😘 🎨
Campagnolo 1010/b dropouts
Losa lugs as at least the head tube ones, and seat tube
dimpled seta-tube*
pantos on bottom bracket shell*
*often seen on Losa build/brazed frames...
Fanini Super - Lorezno Fanini, Lucca, Toscana
grazie @redo 🙏
twin head / double head fork crown - testa forcella 😍🥰
with
braze-on brake caliper bolts 🔩 🔥
drilled vertical Campagnolo 1066 dropouts 🏎️
custom braze-on front derailleur ✨
long extended lower head tube lug tang 🥇
chromed head-tube lugs 🌟 and fork reinforcement tangs 💎
no bridge between chainstays!
shift lever braze-on with integrated lever stop ⏹️
Cicli Casati, Monza - Lombardia
founded 1920 by Pietro Casati (12th October 1891 - 2nd February 1956) - buon corridore.
Gianni Casatis sons are now in charge, the 3rd generation - Massimo & Luca
Gianni Bungo raced as an amatuer on a Casati (80s)
fillet brazed & lugged 🔥
sweet fork crown! 📐 💎
rear derailleur cable stop brazed on dropout 📏 🔩 🔥 ⏹️
sadly both seatstays have been drilled for fender mounting... 😬😑🙄
still red - rossa come la Ferrari! 🏎️ 🐎
Savigni, Filiberto
1973'
brazed by Patelli Peloso I* would guess 🤓 🧐 ;-) 👼🏾
+GF+ Georg Fischer sand cast bottom bracket shell, swiss CH
Schreibe deine Antwort....
