Nur weil die Frage hier bzgl. der
AXS * aufkam, erlaube ich mir meinen Post bei den
Weight Weenies zu zitieren.
Es geht um SRAM * AXS * Schaltung (Rim) mit Shimano * Antrieb. Habe ich so umgebaut an einem Aeroad und einem Ultimate, je 2020:
I got the following setup running smooth and quiet (tested 50 km Swift and 75 km hilly route outside):
Force Shifter (Rimbrake)
Force RD
Force FD D2 (2023)
12s Cassette Ultegra 11-30
12s chain 105
11s crank 105 driveside
10s crankarm Ultegra left (stages)
It takes a bit of time to understand the FD and installing the wedge was tricky on my Canyon Aeroad because of the wide seattube. You can't reach the thread from the non driveside to fix the wedge with the little screw when the FD is already installed.
Never thought
AXS * etap works so good with all else
shimano *.
Note: My 105 rim brakes bites significantly better with the Force shifters.
