Scatola movimento centrale d'artigano | Tretlagergehaeuse - Rahmenbau-Liebe Im Detail (Handwerkskunst) | elaborate bottom bracket shells
Tiziano
269
Highlight third picture
right rear stays are modified on the inner side towards the dropout
like Chiesa used to do it and then later his two alumni Bruno Fantini as Gianni Rivola or by Patelli... 🤷🏾‍♂️ :D
vendor says made in Ortellis workshop where mechanic Tiziano worked🤷🏾‍♂️ could be a Fantini or Patelli too 😂🤷🏾‍♂️:D
Anhang anzeigen 1073537Anhang anzeigen 1073547Anhang anzeigen 1073546Anhang anzeigen 1073543Anhang anzeigen 1073545Anhang anzeigen 1073538Anhang anzeigen 1073540Anhang anzeigen 1073542Anhang anzeigen 1073541
Wenn dann Patelli wegen des mittleren Zugröhrchens unterm Tretlager. :)
Re: Scatola movimento centrale d'artigano | Tretlagergehaeuse - Rahmenbau-Liebe Im Detail (Handwerkskunst) | elaborate bottom bracket shells
und dem kleinen zusaetzlichen Fuehrungsring.
https://www.rennrad-news.de/forum/t...ket-shells-frame-building.167126/post-5140011hier Patelli 239 auch mit den ganz feinen Steuerrohrmuffenpanto seitlich, aber aero Schaltzugfuehrung
Nun flogt
Cilci Patelli
55
same panto on stem like on Cicli Rivola - same panto maestro Gino Cornazzani??? teH guy for Ortelli too!!!
Cinelli CCM investement cast (micorfus/Feinguss) bottom shell by Micorfuisone italiana
light luglining on headtube lugs/highlighting
like Chiesa used to do it (for Rivola too) and then later his two alumni Bruno Fantini as Gianni Rivola
Bruno Fantini
alumni d' Umberto Chiesa di Bologna
Bruno Fantini
Specialissima 1981
Campione D' Italia
Via Borgovado, Santa Maria in Vado
livrea - paint 🥵😍
flat fork crown ♥️ with »F« panto 🙏🏽
braze-on brake bolts
extra long seatstay caps 🥵😍 uffff
curved brake bridge 🎨
no bridge between chainstays ⚖️ lighter 🪶 & shorter wheel base 🏎️
Campagnolo 1010/b dropouts
Columbus SL tubing
Anhang anzeigen 1036876Anhang anzeigen 1036882Anhang anzeigen 1036877Anhang anzeigen 1036881Anhang anzeigen 1036878Anhang anzeigen 1036879Anhang anzeigen 1036880Anhang anzeigen 1036883Anhang anzeigen 1036894
11Fantini bici corsa rossa braze-on brake caliper bolts front and rear (6).jpg
1Fantini bici corsa rossa braze-on brake caliper bolts front and rear (2).jpg
  • Screenshot 2022-04-17 at 15-28-33 1971 Italian Masi Gran Criterium painstakingly rebuilt by Ri...png
TIZIANO
crono/cronometro - time trial
039
by So(cietà)Mec(canica) - society of mechanics - Somec
6 Via S. Vitale, Lugo di Romagna, Italy 🇮🇹
Founded June 1973 by Oliviero Gallegati & Associates like probably Pierino Scarponi... 🤷🏾‍♂️
beautiful head tube Panto (this time coloured 🎨 😍)
like on the other Tiziano, double differing by Ortelli as the vendor states,
which contrary has a detail spotted only frames build by maestro Umberto Chiesa di Bologna, his two alumni Bruno Fantini nella via Borgovado di Santa Maria in Fado, Ferrara 🇮🇹 and Gianni Rivola di Massalombarda a Ravenna, nell' Emiliga-Romgna or certain Patelli s 🤷🏾‍♂️ and will be build by latter Patelli.
typical SOMEC style of fastback seatstay cluster as the somec tulip 🌷 panto on the lower head tube lug
typical SOMEC fastback seatcluster 🥰 😍
