Scatola movimento centrale d'artigano | Tretlagergehaeuse - Rahmenbau-Liebe Im Detail (Handwerkskunst) | elaborate bottom bracket shells
Rivola
since 1963 till 2005
@ Massalombarda, Ravenna, Emilia-Romagna 🇮🇹
brazed by Gianni Rivola, second son of founder Giovanni Rivola, first son was named Coppi after the Campionissimo from Novi Ligure. First inhouse frame builder Rivolas was Umberto Chiesa ⛪ di Bologna.
914
foderi carro posteriore a coda di rondine - Schwalbenschwanz Hinterbaustreben - dovetail rearstays
Campagnolo 1010/b Porta catena dropouts porduced by Tecnociclo Sestese, of G. Papalardo @ Milano
Colmbus MultiShape tubing
verniciatura (paintwork) Mario Martini di Lugo, Ravenna
116879850_10216876605730640_6867008780611434551_n-jpg.1069782
116880513_10216876576889919_6520101680760981399_n-jpg.1069779
116889925_10216876597330430_5169126541990816504_n-jpg.1069773
116898092_10216876598610462_6969185472791149515_n-jpg.1069784
Re: Scatola movimento centrale d'artigano | Tretlagergehaeuse - Rahmenbau-Liebe Im Detail (Handwerkskunst) | elaborate bottom bracket shells
Olivetti
Reggio Emilia in Emilia-Romagna
framebuilder 🤷🏾‍♂️
bottom bracket shell remindes of Pelàs timeless classic »butterfly« 🦋 cut-out, dropouts are a coda di rondine (dovetail) fashion Orazio Grenzis, on the following Olivetti the fork blades reinforcement tangs have hearts 🖤 cut-outs like Luigino »Gino« Milanis (but not on the {rear} brake bridge🤷🏾‍♂️🤌🏾), PLUS look how the right rear stays are modified towards the dropout on the "inside" 😳 like by Umberto Chiesa ⛪ and later Gianni Rivola???
sus sheesh 😳🤷🏾‍♂️ ma come 🤌🏾 🤌🏾
mannaggia 😳 🤌🏾 acci-picchio🤌🏾
🤌🏾 pofferbacco 🤌🏾
🙏🏾 perdindirindina 🙏🏾
Number two:
318d4caa-68e6-49af-b906-8aab9d384e1e-jpeg.753983
63d1d8a2-75e3-4415-8ff0-09d4b304449b-jpeg.753980
627c2b28-4e13-4dbf-ba04-4d9ce15d2d61-jpeg.753978
7c4188ed-f0a4-496b-8bc6-1e64239e463c-jpeg.753981
Olivetti
from
Reggio Emilia in Emilia-Romagna {👋 ol' Ravi 'Rivola}
seatlug reminds of early Rivola s by Chiesa or frames of the Volta s
maybe then revised and new fork with a panto common for Orazio Grenzi s on Maurizio, Olivetti, Vaccari and so on. Other distinctive mark Grenzi s sometimes is the sliglthly ligtning shaped ⚡ reinforcement tang of the fork crown. 🙏🏾
(ventilation bore of the chainstay bridge orientation facing direction of travel, like on the pink flakes Maurizio or the darker champagne Olivetti... and this one 🔍is even located/placed/drilled decentral 😳 🥰😍 Chiesa ⛪ ???)
special Campag dropout, very short production period!
cheers.
Gibt's ein Foto von der gabelzunge? Hat schon fast was von einem milani, wären da nicht die ausfaller.
Wird es jetzt interessant ;-)?
Bisher nicht oder zumindest nicht zu Gesicht bekommen, frag mal @Isostar 🤷‍♂️.
Bin ja nicht so zimperlich mit 📸.
:D
Sodele :D (datt orangene Maurizio befindet sich auch hier im thread).
Olivetti
framebuilder 🤷🏾‍♂️
🤌🏾 pofferbacco 🤌🏾
Anhang anzeigen 1071709Anhang anzeigen 1071710Anhang anzeigen 1071711Anhang anzeigen 1071712Number two:
Anhang anzeigen 1071713Anhang anzeigen 1071716Anhang anzeigen 1071715Anhang anzeigen 1071717Anhang anzeigen 1071718
Olivetti
from
cheers.
Anhang anzeigen 1071728Anhang anzeigen 1071725Anhang anzeigen 1071726
Anhang anzeigen 1071727Anhang anzeigen 1071724Anhang anzeigen 1071730Anhang anzeigen 1071732Anhang anzeigen 1071729Anhang anzeigen 1071731Anhang anzeigen 1071733
Cicli Patelli
Bologna, capoluogo dell' Emilia-Romagna
right rear stays are modified on the inner side towards the dropout
like Chiesa used to do it and then later his two alumni Bruno Fantini &Gianni Rivola or Patelli... 🤷🏾‍♂️ :D
same lugs as on a Ortelli, (Fantini, Aldo, Oriello, Dosi almost)
two different panto on the head tube lugs, upper differs from lower 🧐 👈 :D
the lower version is used on the Patelli of this post, more rarely seen, the upper is more common.
1640128764396-jpeg.1026570
80211433_10218336092826632_7218455309939900416_n-jpg.1011944
102292279_10158500147396392_6039149001206556299_n-jpg.1048817
102434827_10158500147236392_6993916587838410996_n-jpg.1048822
😳 sus 🤌🏾 sheesh 🤌🏾 mamma mia!!!
accipicchio 🤌🏾
perdindirindina 🤌🏾
Tiziano
269
Highlight third picture
like Chiesa used to do it and then later his two alumni Bruno Fantini as Gianni Rivola or by Patelli... 🤷🏾‍♂️ :D
vendor says made in Ortellis workshop where mechanic Tiziano worked🤷🏾‍♂️ could be a Fantini or Patelli too 😂🤷🏾‍♂️:D build by the latter Patelli, derailleur cable guiding style under the bb shell gives it away to the eagle 🦅 👁️ eyed 🧐 among us :D 🙏
Tiziano
269
Anhang anzeigen 1073537Anhang anzeigen 1073547Anhang anzeigen 1073546Anhang anzeigen 1073543Anhang anzeigen 1073545Anhang anzeigen 1073538Anhang anzeigen 1073540Anhang anzeigen 1073542Anhang anzeigen 1073541
Wieso fehlen jegliche Zuganschlaege/cable stops (wie beispielsweise Campagnolo #621)?
